mossawi Posted December 7, 2020 Share Posted December 7, 2020 Hi guys, I've been having some issues with my renders lately, not sure why and how to fix it, would really appreciate your input on what I might be doing wrong. 1- Here I was working with ACES color management, exporting as .exr, and I did a lot of research and for some reason, it seems like its a bit complex to get the colors to work properly without converting it back to srgb (not sure, I felt kind of lost with this process), please see the comparison between my render preview and render attached. 2- So I moved on to SRGB, tried to fix the settings up, and the same thing my export is looking different. In both cases, I tried it with POST EFFECTS on or off, neither gives me the right result. Here are the .hip files, thanks a lot guys! ACES- https://drive.google.com/file/d/1KqcEHkcUY_2URnn3SEzigposFiyGU1uG/view?usp=sharing SRGB - https://drive.google.com/file/d/1BiCTyKVyEhhN2c6afDqXDi-2SjnVQPk0/view?usp=sharing Quote Link to comment Share on other sites More sharing options...
TobyGaines Posted December 26, 2020 Share Posted December 26, 2020 What are you using to view the "render" versions of the image? Its display settings are clearly different from those of the 'render preview'. Quote Link to comment Share on other sites More sharing options...
