How to accumulate attribute on the array inside dopnet
hodini
i am working on the firework effect.
i emitted some particle by pop locate and they replicate some particles when dead.
Each original particle has orginal id and the id is inherited to replicated particles.
What i want to do is assign the normal vector of Geometry( sphere)  to the velocity of replicated particles
and  adjust them along the each original id. so i decided to iterate over original id with For loop inside popnet.
I made array list of original id and each id inside the array is taken by Find attribute value count
and again loop over with the count of point number that has each id on the array list.
The point number that has certain id is bringing into the list called "plis" but the list is updating and deleting,adding new pointnumber.  It is not accumulating.
how can i fix this ? - my array isn't accumulating but adding one point number and updating the others repeatedly.
and  Do i complicate the process to make little bit simple effect ?
Yes its The Best Way ..and Your File Its Just Beautiful ..Like Compositor-Beethoven:rolleyes: You have Done those nodes :ph34r: : thanx for sharing
@hodini Please Just post Your File Because In this Forum Trust me You have Some Ladies And Dudes that Can help You if you Provide Your File ..Its Very Strange to Assume What You have In your Setup :wub:
Edited by Librarian
??? wtf
