bobbybob Posted December 16, 2020 Share Posted December 16, 2020 Hi. I have a curve that has one sharp bend. I want to smooth/relax the bend, without smoothing the rest of the curve in a procedural way. Is it possible somehow to smooth the curve based on curvature. The two images show how the curve is now, and how I could like the sharp edge to look (correct) curve_example.hip Quote Link to comment Share on other sites More sharing options...
Librarian Posted December 16, 2020 Share Posted December 16, 2020 (edited) Resample Sop- resample by Polygons Edge-Maximum Segments- Treat Polygons As Subdivision Curves @bobbybob Sorry for the quick response earlier Maybe This Also Can by Useful ! Who Knows float maxedgelength = chf("maxedgelength"); int n = npoints(1); // create a polygonal primitive, returns primitive number int polygon = addprim(0,’poly’); //run over the points of the spherical curve for(int i=0; i<n; i++){ vector currT = attrib(1,’point’,’P’,i); vector nextT = attrib(1,’point’,’P’,(i+1)%n); float edgelength = acos(dot(currT,nextT)); vector B = normalize(cross(currT,nextT)); int d = floor(edgelength/maxedgelength); if(d!=0) edgelength/=d; vector4 q = quaternion(edgelength, B); // add subdivision points vector T_tilde = currT; do{int point = addpoint(0,T_tilde); addvertex(0,polygon,point); T_tilde = qrotate(q,T_tilde); d--;}while(d>0); } Smth.hiplc Edited December 18, 2020 by Librarian 1 Quote Link to comment Share on other sites More sharing options...
bobbybob Posted December 18, 2020 Author Share Posted December 18, 2020 Hi @Librarian thank you so much for the answer! I ended up with a ghetto solution relative to your answer I used a measure node, to get the "curvature -> to group -> expanding group -> blasting points -> smoothing" curve_example_ghetto_solution.hip 2 Quote Link to comment Share on other sites More sharing options...
