papsphilip Posted December 17, 2020 Share Posted December 17, 2020 (edited) I am trying to find points with the same xz but different y. Keep the lowest and highest of each xz pile . Make a new clean polyline from those. i need some help with my vex code, argsort isnt working as i expected, i cant find out why sort.hip Edited December 17, 2020 by papsphilip Quote Link to comment Share on other sites More sharing options...
Alain2131 Posted December 17, 2020 Share Posted December 17, 2020 (edited) Hey Philip ! That's an interesting one. I took a slightly different approach than you did So basically, in a wrangle over detail, I set some general variables. Mainly, two arrays. One to store the centers, and another one to store the ymin and ymax (as a vector2). The idea is to then run over each points, and compare their position to the centers (with a threshold, like you did). If the position match one of the centers, then we get the relevant ymin and ymax, and update them if the current position is higher or lower. If there isn't a match to the centers, then that means we have a point from a new line. So we add the point as a new center, as well as ymin and ymax (initialized to the same value). And that's it ! There is a second loop to create the polylines from the data collected by the main loop. int almostEqual(float a, b, threshold){ return b + threshold >= a && b - threshold <= a; } /* Those two arrays will always have the same length. Their index correspond to the same center */ vector centers[]; // contains x and z positions for each center vector2 yvals[]; // contains ymin and ymax for each center /* The idea is for each points, compare its position to the centers When it matches, update the yvals if it is higher or lower If there is no match, then we add a new entry to both centers and yvals */ float threshold = 1; // this is the same as your tolerance for(int i=0; i<npoints(1); i++){ vector curP = point(1, "P", i); int found = 0; foreach(int j; vector center; centers){ int x = almostEqual(curP.x, center.x, threshold); int z = almostEqual(curP.z, center.z, threshold); if(x==1 && z==1){ found ++; // update yvals if the current height is higher or lower float ymin = yvals[j][0]; float ymax = yvals[j][1]; if(curP.y < ymin) yvals[j][0] = curP.y; else if(curP.y > ymax) yvals[j][1] = curP.y; // We already matched, so we know that no other center interrests us. break; } } if(found == 0){ //add to center and yvals append(centers, set(curP.x, 0, curP.z)); append(yvals, set(curP.y, curP.y)); } } // Create Lines for(int i=0; i<len(centers); i++){ vector center = centers[i]; vector2 yval = yvals[i]; vector p0 = center; p0.y = yval[0]; vector p1 = center; p1.y = yval[1]; int newP0 = addpoint(0, p0); int newP1 = addpoint(0, p1); addprim(0, "polyline", newP0, newP1); } Here's a quick gif overview Hope that helps ! sort.hipnc P.S. In retrospect, I could have used an array of vector4, used x and w to store the x and z center, and used y and z to store the ymin and ymax. That would leave us with only one array. Would it be cleaner ? Or simply harder to understand ? You can be the judge of that. Edited December 17, 2020 by Alain2131 1 Quote Link to comment Share on other sites More sharing options...
papsphilip Posted December 18, 2020 Author Share Posted December 18, 2020 thank you very much for the detailed explanation, i am going to study this and try to find what was wrong with my vex its really frustrating when you cant find your mistake Quote Link to comment Share on other sites More sharing options...
