Particle Exercise
MIguel P
  • 2 months later...
  • 2 months later...
Hello Miguel,
I've seen the Tornado on your website. Which method did you use to shade the tornado?
Did you use sprites and if, is this the same VOP shader as your Meteor tutorial ?
many thanks,
bern
It is rendered in 3ds Max using AfterBurn volumetric renderer. Houdini particles exported to Max.
