TOPs ropfetch not saving correct simulation
I have an rbd simulation that works as I expect, if I save the cache with a filecache node it works without any problem.
Aterwards I tried using TOP nodes for running several wedges and this is where things stopped working; the wedge attribute updates fine and if I run the filecache node by itself it's able to save the simulation like I expect it to.
but when I run a ropfetch node it doesnt save the correct cache…all the variables like the wedge index and so on show just fine in the expressions but the actual saved cached file looks nothing like the one I did earlier with the filecache node itself.
Anybody have any idea what could be happening ?
