vfortin Posted January 12, 2021 Share Posted January 12, 2021 (edited) I sort of assumed this wouldn't work but asking here in case someone knows a workaround... Can CHOPs be used within a Foreach compile block? In this setup, a Spring chop overrides a Bend sop and the whole thing is wrapped inside a ForEach loop to offset the timings. Enabling compiling breaks the timings. H18.5.351 thanks! compile_chop.hip Edited January 12, 2021 by vfortin Quote Link to comment Share on other sites More sharing options...
mathieuN Posted January 13, 2021 Share Posted January 13, 2021 Hello, Assuming you are in H18.5 with the new variant attribut. for me chop is not a good option in your case. It's gonna be a real nightmare to you if you want to add variation in your bend ... What you can do is to bend your geometries right after the copy with a curl deformer much more faster. After that you just need to add chop effect on attributs. It's much more effective to me. Hope it's help. Mathieu Negrel. copy_index.hip copy_index.hip Quote Link to comment Share on other sites More sharing options...
vfortin Posted January 13, 2021 Author Share Posted January 13, 2021 Nice one Mathieu I'll try moving most of the processes outside of the loop and see how it performs. Much appreciated, thanks! Quote Link to comment Share on other sites More sharing options...
