art3mis Posted January 13, 2021 Share Posted January 13, 2021 Can anyone explain the pros and cons of using the new Retime SOP vs adjusting Time Scale on the solver when you want to slow down a vellum cloth simulation? Quote Link to comment Share on other sites More sharing options...
Pazuzu Posted January 14, 2021 Share Posted January 14, 2021 (edited) The first thing that comes to my mind regards advantages is that re-timing at post sim doesn't need many frames as a sim will do if for example you need to slow down things at a very low rate. Also post re-time let you change easily the rate without re-siming; there are more advantages, but I think this is the key one. Edited January 15, 2021 by Pazuzu Quote Link to comment Share on other sites More sharing options...
