Mark01 Posted January 15, 2021 Share Posted January 15, 2021 hi all ! I have a basic vellum grains setup. I need to modify the clumping to make the grains stick together less and for the grains to move more freely. Any suggestions which setting in the grain solver I should be modifying?? Thank you! Quote Link to comment Share on other sites More sharing options...
luoqiulin Posted January 17, 2021 Share Posted January 17, 2021 you can use vellumconstraints node and set constraint type to Glue group type to points.or just use connectadjacentpieces node and then add necessary attribute as type stiffness. Quote Link to comment Share on other sites More sharing options...
paranoidx Posted February 2, 2021 Share Posted February 2, 2021 There are: Attraction in Vellum Solver Vellum Constraint with glue or distance You can mix both to help enable the most looks for your taste. Quote Link to comment Share on other sites More sharing options...
