Compile Block Inside HDA
Dumarus
Hi guys,
I have a problem with the compile block inside HDA.
I is working fine unless I add a second asset right after the first one. Then things go crazy because this second asset claims that the Stroke Node that is not even in the first compile block is not Compile compatible and it cannot cook.
Should I isolate the stroke from the compile block?
Tom
