Cutting out piece of geo with curve
anbt
Hello guys, I feel this has been asked probably a thousand times, but I can't really find a simple answer.
I have projected this curve onto this surface with a Ray sop.
I basically want to divide my geometry into two islands with this curve and delete the bottom part.
Any ideas?
Thanks a lot
I wanted to try with the Project SOP but it requires Nurbs surfaces. I converted my half sphere into Nurbs surface but the problem is that I end up with as many Nurbs surfaces as there are primitives. To make the convert SOP works, I should only have one apparently.
How can I convert all the surfaces into just 1? I tried with the Join SOP, no success.
Any ideas?
Cheers
@anbt Oldyyy Nostalgia
  and some link to _______ if you gonna use Sphere only on and for modeling .This dude posted long  time Ago File(Nice Tricks) and if you combine Pretty much you can make(model) anything easily I think.
OldMAgic.hiplc
018_share(3).hip
Edited by Librarian
