controlling points
Is it possible to have a point on an object with a scatter and control it so that the scatter avoids the sphere?
I'd like to control the sphere with transform.
When Sophia passes through the object, the object in the area she passes through seems to expand.
Thank you.
@yujiyuji
Expand In what Form?(if you play With IsoOffset you have nice control) ,depending on Actual effect , (Like Sophia's Passing object part, that she use ,or just Like sticking to actual Geo Of Sophia and what Type of control You want to have over those points ?
Maybe it Helps ! Have Fun
//Input 2 is Geo
//Input3 is SDF representation of Geo
int handle = pcopen(@OpInput2, "P", @P, chf("rad"), chi("num"));
vector lp = pcfilter(handle, "P");
i@npt = nearpoint(1,@P);
vector npos = point(1,"P",i@npt);
vector off = set(0,chf("yoffset"),0);
vector disp = @P-lp;
float vsample = volumesample(2,0,@P);
if(vsample<0)@P-=disp;
