Recognize Disconnected Mesh As A Connected Mesh?
bentraje
I have two disconnected mesh. By default, Vellum recognizes pieces based on "connectivity".
In this case, it will be two separate meshes.
However, I want them to be simulated as one but not having them as merge/weld points.
I tried the Define Pieces>From Attribute option but they are still simulated as two meshes.
Is there a way around this?
You can check the illustration video below:
hou007_vellum_cloth_recognize_one_singular_mesh.mp4
Illustration file:
hou007_vellum_cloth_recognize_one_singular_mesh.hipnc
3 hours ago, bentraje said:
Illustration file:
use in Tab menu Vellum Weld Points, in Group parm choose points you want to be connected while simulation.
