scuy Posted February 11, 2021 Share Posted February 11, 2021 About "POP Axxis Force" I just set center position from input 1 point. Dose anyone know hot to set this? My vex code is error. Quote Link to comment Share on other sites More sharing options...
anim Posted February 11, 2021 Share Posted February 11, 2021 unfortunately the actual variable names are not always consistent with parameter names sometimes (if implemented) it helps to use the dropdown arrow on the right and choose Pass Through to show you the names in your case you want to change 'center' variable, so something like: center.x = p.x; 1 Quote Link to comment Share on other sites More sharing options...
