copy to points - assign textures from folder
I have a simple geo i instance on a bunch of points using copytopoints SOP.
i would like each of the instanced object to be assigned a specific texture from a folder.
1 ) i have a string attribute of the path to the corresponding image for each point.
2) i promote it to primitives after the copytopoints
3) i use material override basecolor texture
the problem is an error pops saying unable to load texture or "libpng error: Not a PNG file"
Edited by papsphilip
