Python 3, using old Python 2 scripts
Krion
Hi,
I have just installed the Python 3 version of Houdini to test out if I can use old code with it. I had read something about an included convert-script.
My own shelf tool which references an old python script in an own PYTHONPATH of mine produces this error:
6048e5ccf3a9c_Screenshot2021-03-10at16_27_49.png.4a85781dc1da68c81b8b75436d1aea16.png
Do I need to rewrite all my old code?
Thanks,
There is no such a big difference between Python2 and 3, so re-writing should not be hard.
In Python 3 "print" is not a statement anymore, it is a function, which means you have to place everything in parentheses: print ('Hello, World!')
This is simply not true. There's a huge difference between python 2 and 3. There's a reason why there's still massive amounts of Python 2 code around even after 12 years since Python 3 came out.
Changes to import mechanics, strings and unicode, iterators, metaclasses just to name a few. Switching to Python 3 is not trivial.
For simple scripts, converting manually is a reasonable option, for bigger projects I use this tool: futurize
  Quote
Check out this guide: https://docs.python.org/3/howto/pyporting.html
Edited by Stalkerx777
typo
  • Thanks 1
  • 4 months later...
If you are a beginner then I would suggest you to just learn Python3 as Python3 will take over Python2 by 2020. But, if you are interested in just the differences than I can tell you a few common difference a beginner should know like - Python 2 vs Python 3
  • In Python2 print is like a command but in Python3 print() is a function
  • In Python2 the integer divide works in C/C++ style but Python3 will return the expected result. For example, In Python2 7/2 will return 3 but in Python3 it will return 3.5
  • In Python 2, a string is by default ASCII. But in Python3 string is by default Unicode
  • 1 month later...
Hi there,
I'm very new to learning Python and am running the latest version of Houdini with python 3.
I was trying to run a simple command from a tutorial ( but it's py2 ) . I figured out that you have to now do print("stuff").
In the tutorial
When I run the code with what I thought would be the correct change to syntax:
import hou
my_obj_context = hou.node('/obj')
my_geo = hou.node('/obj/geo1')
print (my_geo.children)
I get the following result:
<bound method Node.children of <hou.ObjNode of type geo at /obj/geo1>>
When I try in an older version of Houdini with py2 I get the actual list of nodes ( but with print my_geo.children() ).
I can't seem to find any tutorials or guides that can help me get into using python in houdini with version 3 and above. Any advise is welcome.
Edited by GDonkey
I'm bad at links :P
Hi, you forget to call the method.
print (my_geo.children) prints that method object. Not calling it.
You need:
print(my_geo.children())
