[SOLVED] Properly taper the ends of PolyExpand?
bentraje
Is there a way to properly taper a PolyExpand node?
I'm planning to have a pseudo procedural ornament and I need the ends to tapered.
I'm using the local attribute "offsetscale" to have variable width/offset but when I set it to zero, it just offsets unexpectedly.
You can check the illustration of the problem here
spline.abc
taper_polyexpand.hipnc
taper_polyexpand_illustration.mp4
Edited by bentraje
