poketruc Posted April 1, 2021 Share Posted April 1, 2021 Is there a way to wire nodes with keyboard ? Let me explain we select two or more nodes and with a key nodes are wired ? Thanks Quote Link to comment Share on other sites More sharing options...
Atom Posted April 1, 2021 Share Posted April 1, 2021 (edited) Select a node and right-click on the bottom or top connector. Choose a node from the list and press enter. This will "auto-wire" the new node to the selected input. Another auto-wire feature to select a node, choose a new one from the list using SHIFT-ENTER. This will auto connect the new node. You could create a hot-key mapping to a custom shelf tool that will "auto-wire" a selection. The hard part is knowing which nodes to connect first? Is selection set order determined by mouse box lasso? (top to bottom or bottom to top?) Edited April 1, 2021 by Atom Quote Link to comment Share on other sites More sharing options...
