Max_Steven Posted April 6, 2021 Share Posted April 6, 2021 (edited) Hello, I have a bunch of feather patterns that i want to be in order of a curve Right now I can make it to 3 version, but I have 6 so I couldn't figure out a cleaner way to do it So from the current curve point order I want to align feather pattern 1 to 5 and the last point will be pattern 6 I'm almost there just need a cleaner way rather than compare from 0 to 6 I hope I explained it clearly. Thank you for your time Ask_Copy_With_Variation_In_Order.hip Also right now I can procedurally place feather along the wing but doesnt have anything to create the S of curve at the end of the wing. If you think of anything I would love to hear Edited April 7, 2021 by Max_Steven Quote Link to comment Share on other sites More sharing options...
Ultraman Posted April 7, 2021 Share Posted April 7, 2021 5 hours ago, Max_Steven said: Hello, I have a bunch of feather patterns that i want to be in order of a curve Right now I can make it to 3 version, but I have 6 so I couldn't figure out a cleaner way to do it So from the current curve point order I want to align feather pattern 1 to 5 and the last point will be pattern 6 I'm almost there just need a cleaner way rather than compare from 0 to 6 I hope I explained it clearly. Thank you for your time Ask_Copy_With_Variation_In_Order.hip something like this? Ask_Copy_With_Variation_In_Order1.hip Quote Link to comment Share on other sites More sharing options...
Max_Steven Posted April 7, 2021 Author Share Posted April 7, 2021 Thanks for your reply It looks right at first but when i set feather number to 6 then the variant number only goes from 0 to 3 And when it's set to 1 the result is really odd Quote Link to comment Share on other sites More sharing options...
