Ripple solver issue
younglegend
  On 4/8/2021 at 2:01 PM, Librarian said:
@younglegend  IF you play with settings you can Adjust ...I like to have rest and Init outside..separate...Maybe you need v..or lower Conservation
RipplesXC.hipncFetching info...
Expand
Hmmm....the grid seems to be still moving down a tiny bit. Can be ignored in my case but i'm still curious why.
One workaround i'm doing is using dot product and use the values in the shader to displace.
