local variable explain
amin.khormaei
https://www.sidefx.com/docs/houdini/network/expressions.html#variables-and-attributes
Local variables. Nodes often provide variables that are useful for expressions on nodes of that type. For example, a node that operates over the points in a geometry will have a @ptnum variable representing the point number of the current point. The help for a node will list the local variables you can use in expressions on that type of node.
