Brute force square/rectangle packing in non square grids?
Currently wondering if it's possible to do something similar to the image below:
http://imgur.com/a/wdZXpHU
I want to be able to pack rectangles and squares into a uneven grid of points, 2x2, 2x4, 1x3, etc.. I'm not sure how to go about this those as it doesn't seem as simple as making a 2d array and checking if a pointer goes out of bounds?
I don't mind if it's brute forced as all the squares don't need to be filled, just most of them. Struggling to find a solution to this though
Edited by Pidgy
The points in your image still appear to be a regular square grid with irregular edges, so you could probably accomplish what you are looking for using a grid and some VEX to delete prims that you don't want.  I would probably delete them randomly in a while loop, then come up with a check that would be able to detect the patterns.  I will have to noodle on it, though I do have some ideas.  I'm thinking using area vs perimeter to check if a block has become a valid shape since there is a unique set for both that will mean it has the right shape.  That only works if you have a uniform area per prim though.  If you want to use non-uniform, it gets much more complex.  Doing it this way could actually allow you to select any shape, though mirrors would be identical so an L shape could be possible to find, but the other 3 variations of it would pop up as well.  You could also have a half-edge calculation walk around the shape and check the number of corners, so any 4 corner shape would indicate that it is a rectangle, anything more would be ignored.
No matter how you slice it, you are asking about a very interesting Comp Sci/Math problem.
Unless I'm misunderstanding, this seems to essentially be a shape/object packing problem - there have been threads on that here with a number of example files, so if that is indeed what you're after, I'm sure you'll find a solution previously posted
Plus an entagma tutorial you might find useful:
https://entagma.com/houdini-17-quicktip-packing-geometry-using-the-uv-layout-sop/
Edited by ryew
including links to previous posts
Fun
points Grid
vector2 pos = rand (@elemnum)-{.5,.5};
pos *= 10;
int pt = addpoint(0,pos);
vector scale = fit01(rand(@elemnum+0.1),{0.2,0.5,1},{1,1,1});
float pscale = length(set(scale.x,scale.y));
setpointattrib(0,"scale",pt,scale);
setpointattrib(0,"pscale",pt,pscale);
vector nor= {0,0,1};
vector up = fit01(rand(@elemnum*0.2),{-1,-1,0},{1,1,0});
up= normalize(up);
setpointattrib(0,"up",0,up);
solver
removevalue(near_pts,@ptnum);
vector avg;
vector scale;
vector pos;
vector dir;
vector up;
int n = len(near_pts);
foreach(int pt; near_pts){
        scale = point(0,"scale",pt);
        pos = point (0,"P",pt);
        dir = @P-pos;
        up = point(0,"up",pt);
                if(abs(dot(up,@up))>0.001){
                        @up += length(@up-up)*(up-@up)/n;
                if(abs(dot(dir,v@side))<scale.x+@scale.x && abs(dot(dir,@up))<scale.y+@scale.y){
                        avg += 1.2*(@P-pos)/pow(length(@P-pos),4);
                        } else if(n<chi("compactnes")){
                                avg += pow(length(dir),2)*(pos-@P)/n;
@P += 0.008*normalize(avg);
outside
int pts[];
matrix xform = instance(@P,@N,@scale,0,@up);
foreach (vector pos;{{-1,-1},{-1,1},{1,1},{1,-1}}){
         pos *= xform;
         append ( pts,addpoint(0,pos));
int prim = addprim(0,"poly",pts);
setprimattrib(0,"Cd",prim,vector(rand(0.1*@ptnum)));
removepoint(0,@ptnum);
Edited by Librarian
