OpenCL Exception in Vellum
OpenCL Exception: clEnqueueNDRangeKernel (-52).  This is probably due to incorrect number of kernel parametrs.
I'm getting this error on each iteration when I try to use a Vellum on a sphere.  I'm just trying to make a basic balloon, and am using the Vellum Configure Balloon preset from the tab menu.  Essentially following the Entagma tutorial for the initial setups then deviating once I get it inflating how I want.
At least, that is the goal.  As it stands, that error just keeps looping until my Houdini crashes when I try to simulate.  I have already choked down my cache size and have the latest nVidia drivers for my GeForce 1080.  I can't find much info online and none of them have resolutions.
Under Edit/Preferences/Miscellaneous, try switching from GPU to CPU for OpenCL.
I have the same problem, even older vellum projects no longer work.
My guess is video driver updates have altered the way Houdini perceives my GPU hardware.
Edited by Atom
  • Like 3
