krishna avril Posted April 21, 2021 Share Posted April 21, 2021 (edited) Hi, Importing alembic from the server is not working, tried to run as administrator still not helping, any ideas? P.s - loading using nodes is working but I need to load alembic scene, I can even navigate and select the file but getting errro when clicked on import Edited April 21, 2021 by krishna avril more info Quote Link to comment Share on other sites More sharing options...
davpe Posted April 21, 2021 Share Posted April 21, 2021 I've seen this before and setting environment variable HOUDINI_ACCESS_METHOD = 2 in my houdini.env file has solved the issue in my particular case. from the docs: HOUDINI_ACCESS_METHOD This value can be 0 (the default), 1, or 2. It selects the method used by Houdini to check file and directory permissions under Windows. 0 checks the permissions of the current user against the Windows user and group permissions set for the file in question. This method may be slow on machines that use a network login server. 1 uses a different method for checking the Windows user and group permissions, but relies on functionality that is broken in Windows 2000 Service Pack 2. Method 2 simply checks the file attributes. This method is fast, but ignores the user and group permissions, and so may report that some files or directories can be written to when actually they cannot. Quote Link to comment Share on other sites More sharing options...
krishna avril Posted April 21, 2021 Author Share Posted April 21, 2021 Awesome Dude, It worked like a Charm! Thanks for the Explanation Quote Link to comment Share on other sites More sharing options...
