Restrict Groom Brush to a Specific Guide?
bentraje
If you have your guide groom sop selected, hit whatever your hotkey to go into selection mode (i have mine remapped because im left-handed), then have the radial menu setup to have screen brush. And you will groom on the guide select.
https://abvfx.me/portfolio/guide-width/
If you jump to the 3:20 mark you will see i use the radial menus to plant and then select the screen brush to sculpt.
Groombear is not required for this functionality.
