itai Posted May 12, 2021 Share Posted May 12, 2021 Hey Guys Im kinda new to Houdini, doing tutorials, I imported this Parrot model, and in the Objects level it looks fine, as expected, but when I go inside the Sop, I get this transparent look, I reset the Display viewport (D) back to defaults, but it wont go back to normal.. Any tips? Thanks! Itai Quote Link to comment Share on other sites More sharing options...
Killswitch Posted May 12, 2021 Share Posted May 12, 2021 hey itai, there is no problem with the viewport you, I'm sharing a snip bellow go there and change it to "show all objects", then everything will be back normal. Quote Link to comment Share on other sites More sharing options...
itai Posted May 16, 2021 Author Share Posted May 16, 2021 Im in the context of this Bird, and the "show all objects" is turned on, and the bird id transparent, even though Im in its context, and with these weird blue curves. When I do a new scene, with this rubbertoy in front of the pig, it shows as transparent... Is there a way to reset Houdini's display? before I re-install it? thanks Quote Link to comment Share on other sites More sharing options...
Atom Posted May 17, 2021 Share Posted May 17, 2021 Quote Any tips? Post the hardware you are using and consult the SideFX minimum requirements page. Quote Link to comment Share on other sites More sharing options...
