VEX volume wrangle
alr77
Dear all,
Am actually encountering a problem. probably stupid for you as experienced users but like a "Huuuhh ?" for me.
So the goal is to "printf" the i@ix, i@iy, i@iz of any voxel in a volume. a vdb here.
So i type in a wrangle node : the source is a VDB from polygon in "surface" SDF mode
printf("vox id vector : %g\n",set(i@ix,i@iy,i@iz));
I swear nothing comes out from that line. And i just cannot understad why as normally the volume wrangle "might" browse each voxel one by one.
may be it is not the case ?
Is anybody had this problem before ? Is it a bug on my side ?
As well any advices are welcome, thank you already ! (i've probably made an error, probably basic but i cannot figure out what ^^)
all the bests, :)
Dear Atom,
First a big thank you to have answered to mys questionnings.
Saddly, it didn't worked (on my side).
BUT i've found a way to go over.
1.Step one was to record : volume origin and volume res (all in a classical detail wrangle)
vector volRes = volumeres(0,"surface");
vector volrOrigin = volumeindexorigin(0,"surface");
setprimattrib(0,"origin",0,volrOrigin,"set");
2.Step two was to "hard write" voxels ids in a vector array. This at the volume prim level :
function vector[] vxids(vector volorigin; int volres[])
    vector vxid[];
    for(int vorx = volorigin.x; vorx < (volorigin.x + volres[0]); vorx++)
        for(int vory = volorigin.y; vory < (volorigin.y + volres[1]); vory++)
            for(int vorz = volorigin.z; vorz < (volorigin.z + volres[2]); vorz++)
                vxid[len(vxid)] = set(vorx,vory,vorz);
    return vxid;
//WRITE VOXELS IDS :
vector volorigin = prim(0,"origin",0);
int volres[] = primintrinsic(0,"activevoxeldimensions",0);
vector voxels_ids[] = vxids(volorigin,volres);
setprimattrib(0,"voxels_ids",0,voxels_ids,"set");
3.Step 3, i just had to read the volume primitive attribute "v[]@voxels_ids".
My test example was to drop points at each active voxel centers (source shape is animated with a mountain node).
Conclusion : contrary to the volume vop, the volume wrangle doesn't read "easily" the i@ix, i@iy, i@iz.
It does BUT it is not obvius for me. (sorry for that).
to read them easily, it is better to hard-write them into a vector array attribute at the volume primitive level.
the funny thing (for me) is that now we could assign values into a volume from the created points. (humbly which looks easier for me as a beginner).
So thank you Atom ! :)
cheers, and all the bests.
I've joined a quick screenshot of the houdini scene.
if you want to have the .hipnc to add some corrections or even have a review on it, no problem, let me know !
alr77
Edited by alr77
