Surface Flow
NLSN
On 5/26/2021 at 1:30 PM, NLSN said:
https://www.behance.net/gallery/92965789/Variras-Naufrage
May I ask how to create this surface flow effect?
Thanks!
I made a very close effect by 1) using Point from Volume and noise, but don't know how to convert the points back to polygon. 2) using noise on surface, however, when I add thickness by poly extrude, come part of polygon stick out. (See below pictures) Anyone can help? Thanks!!
10 hours ago, flcc said:
VDB from particle then some vdb smoothing sdf or reshape, then vdb convert to polygon ?
Fred,
It works. It did not shown at first (even disappeared), then I gave a try on the parameter by 0.001 on every change, it shown up. Good lesson. Thanks a lot!
Best,
Nelson
*If anyone could answer my 2nd question, will be really appreciated :
"After using noise on surface, when I add thickness by poly extrude, part of primitives stick out."
