Linux access problems - "ModuleNotFoundError: No module named 'viewerstate'"
Memo
Apologies for cross-posting, but this is driving me nuts and I can't believe I cannot find any information regarding this online.
I'm getting lots of "ModuleNotFoundError: No module named 'viewerstate'" type errors on Ubuntu. Full details at  https://www.sidefx.com/forum/topic/79385/?page=1#post-341733
but TLDR version is:
I installed houdini (18.532, on Ubuntu 18.04) and licensed (Indie) exactly following instructions at https://www.sidefx.com/faq/question/install-linux/
and then this doesn't work:
 cd /opt/hfs18.5
 source houdini_setup => The Houdini 18.5.532 environment has been initialized.
 hscript => gives all of the errors in the linked thread
but this does work:
sudo /opt/hfs18.5/bin/hscript
and so does this:
 sudo su
 cd /opt/hfs18.5
 hscript => works
Is this normal behaviour? Can I not run houdini without root privileges? If I source houdini_setup in my .profile, then none of that env gets carried on over to my sudo, so I'd need to source it as root.
Edited by Memo
Thanks for the suggestion @bunker. Turns out it's not a permissions issue at all. I've discovered it's because I had separately defined a
HOUDINI_PATH
environment variable pointing to
/opt/hfs18.5
(for my own convenience). So even though I was running
AFTER defining
HOUDINI_PATH=/opt/hfs18.5
, it was still breaking something. (And the reason why it worked as root, is not because of permission issues, but because HOUDINI_PATH was not defined for root).
