Drughi Posted June 17, 2021 Share Posted June 17, 2021 (edited) Hey, I want to compress caches with PDG. The idea is to split the cache in bundles of ~5 and compress them to then be uploaded afterwards. So what I would need to do is remap the work items in a way that they group to a fifth. Every new work item contains the 5 paths to the bundled cache files. If I got this setup I can trigger a python script to trigger the compression. Can someone help? Edit: I just found the filecompress node and will use that. Edited June 17, 2021 by Drughi Quote Link to comment Share on other sites More sharing options...
