microvswind Posted July 11, 2021 Share Posted July 11, 2021 HI all. I want to attach the strings to the rigid tube.but it do not work.please tell me where i was wrong. thanks in advance. Test.hip Quote Link to comment Share on other sites More sharing options...
Pirminus Posted July 19, 2021 Share Posted July 19, 2021 Hi there, so I took a look at your setup and everything should now work as expected. I just created a vanilla attach to geoemtry node and set the point group to top in the first field. Other things leave as it is. It automaticly finds the primitives where it should attach and then it works. Cheers Test_pirmin.hiplc 1 Quote Link to comment Share on other sites More sharing options...
microvswind Posted July 30, 2021 Author Share Posted July 30, 2021 On 2021/7/19 at 3:59 PM, Pirminus said: Hi there, so I took a look at your setup and everything should now work as expected. I just created a vanilla attach to geoemtry node and set the point group to top in the first field. Other things leave as it is. It automaticly finds the primitives where it should attach and then it works. Cheers Test_pirmin.hiplc @Pirminus Hi.sorry for late response.pleasure this problem is solved finallly.I am appreciated for your help.thanks very much. Quote Link to comment Share on other sites More sharing options...
