Opengl Hook
HI Everybody....
I am trying to play with the OpenGL viewport display in Houdini using HDK.
I saw the examples in GR directory. All are based on the GR_RenderHook.
But I have some doubts,
The renderWire function expects GU_Detail,RE_RENDER,GR_AttribOffset... blah blah blah...
The second parameter is "RE_RENDER &ren" and this ren object is used to actually draw the geometry in view port.
eg. ren.beginPoint(),ren.beginLine(),ren.vertex3DW etc.
I want to know more about these available functions. But I couldn't find any docs in RE_RENDER class. My be these are the functions of class from which RE_RENDER is derived. But what is that class????
Plz Help...And plz give me any other info if available...
------iamjaideep
Jaideep Khadilkar
TD,Sciclone Motion Graphics
Hi Everybody........
I am trying to figure out how to draw sprites in Houdini using my new OpenGL Hook.
Can I use the "GL_POINT_SPRITE_ARB" and all other extensions in Houdini????
I am skeptical, because the normal glBegin, glEnd functions don't work, instead we have to use
beginPoint,endPoint functions.
Also would like to know if GLUT and GLEW utilities can work with Houdini.....
Thanking in advance.......
------iamjaideep
Jaideep Khadilkar
