gangland Posted August 7, 2021 Share Posted August 7, 2021 Hello guys, i trying to build an foam layer with a bunch bubbles scatter inside the volume. however the topology of this geometry is changing so the point deform does not work. is there any way to build this points and they sticky in same position while the foam layer its moving? please help me. bubbles_inside_foam.hiplcFetching info... Quote Link to comment Share on other sites More sharing options...
Ultraman Posted August 8, 2021 Share Posted August 8, 2021 On 8/7/2021 at 6:47 PM, gangland said: Hello guys, i trying to build an foam layer with a bunch bubbles scatter inside the volume. however the topology of this geometry is changing so the point deform does not work. is there any way to build this points and they sticky in same position while the foam layer its moving? please help me. bubbles_inside_foam.hiplcFetching info... Expand maybe help u bubbles_inside_foam.hiplc 1 Quote Link to comment Share on other sites More sharing options...
loopyllama Posted August 13, 2021 Share Posted August 13, 2021 here is my take, very similar to Ultraman bubbles_inside_foam.hiplcFetching info... 1 Quote Link to comment Share on other sites More sharing options...
