Correct way of using Z Depth in Redshift
I am trying to render out a simple wireframe with depth i.e. the wireframe object fades into the background. Ideally, I want to control the fading threshold in compositing software but I don't have Nuke which is what most tutorials out there are using.
Relatively new to render passes, wrote Z depth output into EXR but it is recorded in world units I believe so I find it hard controlling it.
I tried using a COP network but can't seem to make it work/don't know how to remap Z depth mask. Any advice on that? Attached file.
On a higher level, what is a good option to use for editing multilayer EXR sequences? I typically use Premiere for simple editing but there aren't many EXR tutorials for it? After Effects seems convoluted. Is Nuke my only good option?
z-depth-test.hipnc
Not really sure what is the problem. Your file seem ok to me.
I just adjust a bit min and max depth.
Effectively these are in world unit, which is quite convenient IMHO.
I also prefere don't use Camera near/far. I Just use it to find the corect min and max values.
By the way are you in bucket mode to tweak parameters ? (Z AOV don't work in progressive mode).
Da Vinci resolve who has a free edition can also do the trick
z-depth-test.hipnc
