Drughi Posted September 27, 2021 Share Posted September 27, 2021 I have a little challange for you guys: How to interpolate a transformation matrix of an instance point in a non linear fashion? Here is a file for you to give it a try. interpolate_transforms.hiplc 1 Quote Link to comment Share on other sites More sharing options...
Drughi Posted September 28, 2021 Author Share Posted September 28, 2021 (edited) Just in case someone want's to do something similar. I've ended up just using the spline function. Instead of a matrix I've choose quaternions and the position vector wich gave me quite acurate results. Edited September 28, 2021 by Drughi Quote Link to comment Share on other sites More sharing options...
jkunz07 Posted September 28, 2021 Share Posted September 28, 2021 (edited) There's no reliable way to slerp matrices as far as I know, typically people will convert the rotation to quaternion then slerp. You can then store the result as a matrix by converting from quaternion back to matrix. This example shows a lerp of the translates, scales and slerp of rotations with the result converted back to matrix. Edited September 28, 2021 by jkunz07 3 Quote Link to comment Share on other sites More sharing options...
mestela Posted September 29, 2021 Share Posted September 29, 2021 Sorta dodging your question really, but I found you can cheat this by getting 3 samples ($F, $F-0.5, $F-1) and feeding them to a sequence blend shape with cubic interpolation enabled. interpolate_transforms_via_blendshape.hiplc 4 1 Quote Link to comment Share on other sites More sharing options...
Drughi Posted January 21, 2022 Author Share Posted January 21, 2022 Thanks for your ideas. This is what I came up with in the end. I did only a rough interpolation and then used resample and subdivide to get adaptive and smooth samples. interpolate_transforms.hiplc Quote Link to comment Share on other sites More sharing options...
