hoknamahn Posted January 24, 2007 Share Posted January 24, 2007 I wonder what the difference between the "old" C style and "new" C++ style of type casting? I've tried to do vector var = (vector)pcfilter... and vcc said that it can't determine which version to use. If I change the code to vector var = vector(pcfilter...)... all is okay. So there is the difference... Quote Link to comment Share on other sites More sharing options...
crunch Posted January 24, 2007 Share Posted January 24, 2007 I wonder what the difference between the "old" C style and "new" C++ style of type casting?... Unlike C++ (but like RenderMan SL), VEX uses the return type as part of the signature. This can create unresolvable type problems Cf = random(noise(P)); This code should generate a warning from vcc since it's impossible to figure out whether the noise() function should return a float, vector or vector4. The C++ style of casting is used to specify the return type explicitly. Cf = random( vector(noise(P)) ); The C style of casting is implemented as a type conversion operation. If you inspect the VEX assembler of the two types of Cf = random( (vector) noise(P)); You'll still get the warning, and you should see that the noise() function generates a floating point value which is then converted to a vector. This is very different than the noise() function generating a vector result by itself. However, since the C++ type-casting style is used for explicit return code specification, it can't really be used for casting one type to another. You have to use the C style. int ival = (int)(s*4.0); A very subtle difference, but a potentially important one. Quote Link to comment Share on other sites More sharing options...
hoknamahn Posted January 24, 2007 Author Share Posted January 24, 2007 Arhhhh... now I see! Thanks crunch Quote Link to comment Share on other sites More sharing options...
