Houdini Alembic exporting without UV
Pj20
Thanks a ton! Thats exactly what i want but even now when i import the abc file into maya ( standard import alembic) i am getting a geo with broken uv(no uv). What am i doing wrong? I took your file and saved to disk 120 frames and imported that only to maya.;( Thanks for the help !!
Im on Maya 2022.2 and is working fine. So it could be a bug in 2019? but I doubt it.
Another way that you can try is through the BF graph which wit will read the alembic way faster plus attributes. Make sure to download the latest BF 2.3.01
https://area.autodesk.com/bifrost/downloads/?_ga=2.135635638.648822367.1633307953-1639519218.1607981494
uvRbd_graph.ma
