Pj20 Posted October 18, 2021 Share Posted October 18, 2021 So i have a very simple destruction sim and i am trying to take it to maya. I had got the obj from maya with the uv. Now when i go to export the alembic sim, the uv doesnt show in maya. Even in houdini i have to unpack the alembic file to see the uv. Could someone help me with this? brick_wall.obj brick.hip Quote Link to comment Share on other sites More sharing options...
Pj20 Posted October 18, 2021 Author Share Posted October 18, 2021 or probably a better way to transfer my destruction from houdini to maya? Quote Link to comment Share on other sites More sharing options...
Sepu Posted October 18, 2021 Share Posted October 18, 2021 Is working fine here I put a clean sop and I just drop a clean rop ABC. uvRbd.ma brick.hip Quote Link to comment Share on other sites More sharing options...
Pj20 Posted October 18, 2021 Author Share Posted October 18, 2021 Thanks a ton! Thats exactly what i want but even now when i import the abc file into maya ( standard import alembic) i am getting a geo with broken uv(no uv). What am i doing wrong? I took your file and saved to disk 120 frames and imported that only to maya.;( Thanks for the help !! Quote Link to comment Share on other sites More sharing options...
Sepu Posted October 18, 2021 Share Posted October 18, 2021 Maya version? Also what rendering are you trying to use out of curiosity? Quote Link to comment Share on other sites More sharing options...
Pj20 Posted October 18, 2021 Author Share Posted October 18, 2021 (edited) Maya 19.3.1 Have not rendered it. This is just out of the viewport. and in the uv editor no uvs are there But i have arnold and maya software to render it bricktry.mb Edited October 18, 2021 by Pj20 Quote Link to comment Share on other sites More sharing options...
Sepu Posted October 18, 2021 Share Posted October 18, 2021 Im on Maya 2022.2 and is working fine. So it could be a bug in 2019? but I doubt it. Another way that you can try is through the BF graph which wit will read the alembic way faster plus attributes. Make sure to download the latest BF 2.3.01 https://area.autodesk.com/bifrost/downloads/?_ga=2.135635638.648822367.1633307953-1639519218.1607981494 uvRbd_graph.ma Quote Link to comment Share on other sites More sharing options...
Pj20 Posted October 18, 2021 Author Share Posted October 18, 2021 Cool thanks ill try it out here in the bf graph and also on another version of maya. Also here is the alembic file and maya import settings just to make sure that there is nothing wrong with that. Download link for alembic https://sendgb.com/u8z6rmIBA9G Quote Link to comment Share on other sites More sharing options...
Sepu Posted October 18, 2021 Share Posted October 18, 2021 Yeah, same options, if I try to load the .abc from you it doesn't work on the vanilla ABC, but in the BF graph, it works just fine. Quote Link to comment Share on other sites More sharing options...
Pj20 Posted October 18, 2021 Author Share Posted October 18, 2021 Could you pls guide me on how to import it and make it work with the bf graph? :) cant seem to figure out how to import it with that Quote Link to comment Share on other sites More sharing options...
Sepu Posted October 18, 2021 Share Posted October 18, 2021 Like this. Make sure you have the Bifrost load in the plugin manager 2 Quote Link to comment Share on other sites More sharing options...
Pj20 Posted October 19, 2021 Author Share Posted October 19, 2021 OMG! Thank you so much man! Quote Link to comment Share on other sites More sharing options...
