What is wrong with my code
Gabriel_Wolf
Hello,
I decided to finally start to learn vex. But I think now I rather suicide. :)
Can you tell me what is wrong with this code?
if (@P.y > 0){
v@Cd = set(0,1,0);}else {
v@Cd = set(1,0,1);}
if (v@Cd == set(0,1,0));{
v@N = 5;}
So basically I what is above zero should be green. And what is green should be get a normal with value of 5.
Thank you
Hi Gabor, it seems to work as expected. You can assign v@N = 5, but when doing so, you are abusing the syntax a bit. Houdini casts that 5 into a vector {5,5,5}
Did you want something like this?
if (@P.y > 0) {
    v@Cd = set(0,1,0);
}else {
    v@Cd = set(1,0,1);
if (v@Cd == set(0,1,0)) {
    v@N = {0,5,0}; // I changed this line
