Razr_123 Posted November 7, 2021 Share Posted November 7, 2021 Hi everyone, I am currently working from a laptop with an SSD. Is there a way I can bypass the SSD (C:/ drive) when caching simulations, and cache them directly on an external HDD (D:/ drive for example)? I don't mean only in terms of path - which of course can be done easily, but also in terms of temp files and the bunch. Mainly to not use my main SSD read/write cycles. Thank you! Quote Link to comment Share on other sites More sharing options...
dleonhardt Posted November 7, 2021 Share Posted November 7, 2021 Houdini has an environment variable called HOUDINI_TEMP_DIR You can set this in the houdini.env to something like HOUDINI_TEMP_DIR=D:\houdini_temp and it should write all temporary files to that directory. 1 Quote Link to comment Share on other sites More sharing options...
