simple vex code for Conway's game of life
regart
Hi there,
I'm quite new to vex and try to build a simple loop to implement the set of rules of the "game of life" by Conway.
The code seems to work for the first iteration, but then stops working as I would expect.
In my example I use a grid with 5 points to be having a attrib value of 1, which is called
i@life
  the others are set to 0.
This goes into a point wrangle:
int count = chi("count");
int life = i@life;
int adj[] = array();
int alive = 0;
adj = nearpoints(0, @P, 10, 9);
removeindex(adj, 0);
i[]@adj = adj;
for(int i = 0; i < count; i++){
    alive = 0;
    for(int p = 0; p < len(adj); p++){
        int iter = adj[p];
        alive += point(0, "life", iter);
    if(life == 1){
        if(alive < 2 || alive == 8) life = 0;
    else if(alive == 3) life = 1;
    i@life = life;
I would very much apprecciate any help on that!
vex_gameOfLife.hiplc
 You need to use a solver sop. Houdini don't keep "global" variables overtime. It's why you need a solver.
I've put your wrangle in a solver and it's do something but more like an infection. Don't know if it's the behavior you expect.
I've also give it a try some time ago, the file is attached. Not perfect and stop working at frame 55. No idea why.
A very good explanation of the solver sop here.
https://www.tokeru.com/cgwiki/index.php?title=The_solver_sop
If you're new to houdini this site is a must see.
It as also a simple game of life example.
https://www.tokeru.com/cgwiki/index.php?title=HoudiniVex#Solver_sop_and_wrangles_for_simulation
vex_gameOfLife + solver.hiplc
GameOfLife_F.hiplc
Edited by flcc
