logix1390 Posted November 10, 2021 Share Posted November 10, 2021 Hello, I am trying to setup a simple blade spinning on an axis using a cone twist constraint. The blade is aligned to the base properly. The blade starts spinning normally but then stops suddenly. It also looks like the blade drops. I will show you a screenshot and attach my file for anyone that wants to take look. Thank you cone_twist_blade_prob.hipnc Quote Link to comment Share on other sites More sharing options...
Ultraman Posted November 10, 2021 Share Posted November 10, 2021 1 hour ago, logix1390 said: Hello, I am trying to setup a simple blade spinning on an axis using a cone twist constraint. The blade is aligned to the base properly. The blade starts spinning normally but then stops suddenly. It also looks like the blade drops. I will show you a screenshot and attach my file for anyone that wants to take look. Thank you cone_twist_blade_prob.hipnc cone_twist_blade_prob1.hipnc Quote Link to comment Share on other sites More sharing options...
Ultraman Posted November 10, 2021 Share Posted November 10, 2021 calc restlength Quote Link to comment Share on other sites More sharing options...
logix1390 Posted November 10, 2021 Author Share Posted November 10, 2021 Thank you @Ultraman . This works much better. It still stopped at a certain point but I put in the "w" attribute in the "Overwrite Attributes" parameter and it works great 1 Quote Link to comment Share on other sites More sharing options...
