Spyrogif Posted November 28, 2021 Share Posted November 28, 2021 How could i add a sop to every geometry node inside a subnet with a complex hierarchy (multiple subnet inside subnet inside subnet etc...talking about non repeating pattern ) Merging everything inside a single geometry to cook my modification is not an option here as i really need to keep my hierarchy paths intact for multiple software workflow and rendering purpose. Scripting looks like the way to go but i m not comfortable enough with it. Any idea how to tackle this specific problem ? Hscript ? Python ? In others words : /// For each geometry node inside a subnet. Add a specific Sop inside geometry nodes. Connect this new sop to the last existing sop . Set the display flag to this new node. Joy. // Thanks for your help. Quote Link to comment Share on other sites More sharing options...
Alain2131 Posted November 28, 2021 Share Posted November 28, 2021 (edited) Hi Spyro, you'll want to use Python for any node network-related manipulation. The relevant functions are node.children() # Return a list of the children https://www.sidefx.com/docs/houdini/hom/hou/Node.html node.createNode() # Create a node https://www.sidefx.com/docs/houdini/hom/hou/Node.html node.setFirstInput() # Connect input to specified node https://www.sidefx.com/docs/houdini/hom/hou/SopNode.html node.setDisplayFlag() # Set the display flag https://www.sidefx.com/docs/houdini/hom/hou/SopNode.html node.setRenderFlag() # Set the render flag https://www.sidefx.com/docs/houdini/hom/hou/SopNode.html node.moveToGoodPosition() # Move the node under its connected parent https://www.sidefx.com/docs/houdini/hom/hou/SopNode.html The rest would be Python logic to decide what to do. subnet = hou.node("/obj/subnet2") # Get a reference to the subnet you want to do stuff to children = subnet.children() # Get all the children of the subnet for child in children: # Loop over each child # Make sure it's a geometry node, since we can have other stuff such as nulls and whatnot nodeType = child.type().name() if nodeType == "geo": # Get Display node displayChild = child.displayNode() # Create Node, parent, and some housekeeping newNode = child.createNode("null") newNode.setFirstInput(displayChild) newNode.setDisplayFlag(True) newNode.setRenderFlag(True) newNode.moveToGoodPosition() This parents the new node to the one that had its display flag set to it. Maybe that's not what you want # Instead of Get Display Node, here's two more options # Get last children # uses the Tree View order (for more info, head to the documentation) children_1 = child.children() lastChild = children_1[len(children_1)-1] # Get last created node # uses the CreationTime metadata # for all children, get the creationTime, and get the youngest one time = children_1[0].creationTime() # initialize time to the first node youngestChild = children_1[0] # initialize youngestChild to the first node for child_1 in children_1: time1 = child_1.creationTime() if time1 > time: # if the current node is younger time = time1 youngestChild = child_1 # And with that, you'd replace setFirstInput(displayChild) with either lastChild or youngestChild Anyways, it all depends on what exactly you want, I needed to do some guessing since we lack an example scene. Here's a scene with an example addSopToChildren.hipnc P.S. I used a weird method to get the script to run when I press a "button". There are much better ways to do it. Here's one → https://projectjulien.space/houdini-tutorials/2018/7/4/create-a-python-snippet-container-on-null-or-any-node Edited November 28, 2021 by Alain2131 1 Quote Link to comment Share on other sites More sharing options...
Spyrogif Posted November 28, 2021 Author Share Posted November 28, 2021 (edited) Fantastic job Alain you nailed it thanks for your help. Just a little thing who's off for my context. Using your example : If you create more geo node inside the targeted subnet inside other subnet inside others subnet etc....it doesn t work. Only the first level childrens are taking into account. Any idea how to tweak the first lines to get all the geo node at any level in the tree hierarchy (with subnets who have differents children depth) ? Still a fantastic and super clear piece of code right now thanks again. Edited November 28, 2021 by Spyrogif Quote Link to comment Share on other sites More sharing options...
Spyrogif Posted November 28, 2021 Author Share Posted November 28, 2021 Was simple as f*** i was just lazy. i ve just replace children() → tuple of hou.Node Return a list of nodes that are children of this node. by allSubChildren(top_down=True, recurse_in_locked_nodes=True) → tuple of hou.Node Recursively return all sub children of this node. For example, hou.node("/").allSubChildren() will return all the nodes in the hip file. Working like a charm in the test scene. Have to test it in a massive scene now. Thanks again . 1 Quote Link to comment Share on other sites More sharing options...
