vinyvince Posted December 5, 2021 Share Posted December 5, 2021 Procedural design research, Heads are tricky... Still have issue to creat the cable network. Im using the quasistic mode with no cache history in vellum as every bot is generated every frame so timeshift is not really what im looking for and i need more than 100 frames after to have my sim stable enough for an output... Still fighting with the collision between cables (cables are not shown in my OpenGL capture below) ... Grrrrgrrhh ________________________________________________________________ Vincent Thomas (VFX and Art since 1998) Senior Env and Lighting artist & Houdini generalist & Creative Concepts http://fr.linkedin.com/in/vincentthomas 3 Quote Link to comment Share on other sites More sharing options...
vinyvince Posted December 6, 2021 Author Share Posted December 6, 2021 Im having issue with Vellum. Im generating a bot every frame (at keeping the seed at frame level is easy for me to quickly check my algorithm) and for my cable network this time i will like to run a vellum sim. I could make it work if i freeze the time no issue there. Now i was hoping the Quasistatic mode will take care of one the input frame is feed, it could run the sim from that without trying to read my input anymore... That's doesn't work. It only doing this if i dive inside and disable 'Timeless no history' but in the case, it's like no vellum simulation . Your suggestion will be welcomed , cheers guys 1 Quote Link to comment Share on other sites More sharing options...
overdose_by Posted January 10, 2022 Share Posted January 10, 2022 That's really awesome! Did you use any VDB for getting these patterns? Is that all done in Houdini or you use other software like Substance for getting patterns? Quote Link to comment Share on other sites More sharing options...
flcc Posted January 11, 2022 Share Posted January 11, 2022 I will be curious to see the network. It must be very dense to say the least. Do you have any idea of the total number of nodes. Including those in asset or subnetworks Quote Link to comment Share on other sites More sharing options...
