bentraje Posted December 24, 2021 Share Posted December 24, 2021 Hi, Is there a way I can create a joint/bone in skeleton node using python? I tried dragging the node in the Python Shell. It has a SOPnode type. I tried running the dir() command under it and it doesn’t seem to have method relating to creating a joint/bone. When searching for “skeleton”, “joint” or “bone”, in the documentation, nothing seems to pertain in skeleton node. Is there a way around this? P.S. Cross posted this in the tech-artist (getting desperate huehue) Will just update accordingly if either side has solution. Quote Link to comment Share on other sites More sharing options...
bentraje Posted January 15, 2022 Author Share Posted January 15, 2022 Hi, Still looking for answer on this one Quote Link to comment Share on other sites More sharing options...
