Flip narrowband and colliders
gangland
Hi
I building an flip simulation that has a shore. i using ocean source sop, in the the second input it has the ("colission geometry") that ive plugged in order to kill the points inside collision geometry.
In dop i created the static object to use as collider against the flip particles. I using narrow band to fill an layer of the surface.
Here's the problem, when the simulation start the particles goes up to the collision geometry and its leaking non-stop messing the whole simulation.
Ive messed with all the parameters but the problem still occuring, ive a felling that it has something with the narrowband, it must have a way to fix that
please help me.
simple hip file:
narrow_band_flip.hip
Edited by gangland
On 1/3/2022 at 3:26 AM, FunnyName said:
Hey Gabriel,
In your collisionsource2 node, volume tab, I reduced voxel size to 0.05 from 0.5. It helped a lot. Try it :).
Hey Pranav, i did you call and somehow the problem persists, it seems a bug.
i did an turnaround that worked for me. in the dop level, i create an delete rule of everything above the ocean surface, then after i few frames i excluded this rule. it works great this time.
thanks for the tip
