Gianni333 Posted January 4, 2022 Share Posted January 4, 2022 Hi guys, I have an issue with visible banding artifacts both in a pyro sim and in a volume generated from polygons with iso offset. The artifacts appear as soon as I crank up the density. The source geo for the static volume is the same as the collider geo for the pyro sim, everything is at the same (high) voxel resolution and from the same highres poygon base geo. Does anybody here know this issue? Quote Link to comment Share on other sites More sharing options...
Gianni333 Posted January 9, 2022 Author Share Posted January 9, 2022 If anybody else runs into this, I didn't find the best answer, but a workaround that worked in that case was to extrude the original collision mesh outwards, make it a volume and substract this from the smoke volume. Quote Link to comment Share on other sites More sharing options...
flcc Posted January 9, 2022 Share Posted January 9, 2022 (edited) May be you better to post a file. Stepping when cranking density on volume doesn't seem strange, and probably I don't have enough knowledge (don't really use pyro) but from the pictures I am not able to say much. Edited January 9, 2022 by flcc Quote Link to comment Share on other sites More sharing options...
