Ryu55 Posted January 6, 2022 Share Posted January 6, 2022 Thanks for reading. I'm now creating creature hair & far grooms in houdini with tutorial. But, I have the problem I have not solved yet. About guide groom node in geometory, in this tutorial, my guide groom node looks like different from tutorial. I have done by following steps it, so I don't know why... You must be very busy, but it would be great if you could let me know your thoughts on the 2 questiions. Thank you. Ryu Quote Link to comment Share on other sites More sharing options...
Sepu Posted January 7, 2022 Share Posted January 7, 2022 (edited) is because you are using a new OTL 2.0 of the guide groom, you can go back to use version 1.0 if you go to Assets > Asset Manager > Configuration and change asset definition to show always then you can change the OTL version. However, you should be able to do the same with the newest OTL. Edited January 7, 2022 by Sepu 2 Quote Link to comment Share on other sites More sharing options...
Ryu55 Posted January 8, 2022 Author Share Posted January 8, 2022 Dear Sepu Thank you very much. It was really easy to understand and I solved it, thanks to you. I really appreciate your thoughtfulness. Quote Link to comment Share on other sites More sharing options...
