About guidegroom node in geometory
Ryu55
Thanks for reading.
I'm now creating creature hair & far grooms in houdini with tutorial.
But, I have the problem I have not solved yet.
About guide groom node in geometory, in this tutorial, my guide groom node looks like different from tutorial.
I have done by following steps it, so I don't know why...
tutorial1.thumb.png.d4a64dfdead985e3c655ad6afb5daa91.pnginmycase.thumb.png.981daede1e7b9d80a8ad5ff3e27f1f6e.png
You must be very busy, but it would be great if you could let me know your thoughts on the 2 questiions.
Thank you.
Ryu
is because you are using a new OTL 2.0 of the guide groom, you can go back to use version 1.0 if you go to Assets > Asset Manager > Configuration and change asset definition to show always then you can change the OTL version. However, you should be able to do the same with the newest OTL.
Edited by Sepu
  • Like 2
