TRH456 Posted January 11, 2022 Share Posted January 11, 2022 Hi all, I started a strange but interesting project, I'm using an app to track whenever I go for a run, it tags a position every 10 meters, it logs Lat, Long and elevation data to a CSV file. The elevation data is in meters already which works fine in Houdini, How would I go about converting the Lat Long data to represent the path I took on my run? I wish I could give a run down of what I've already tried but in all honesty I don't even know where to begin. Some guidance on this issue would be much appreciated. Thanks Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted January 12, 2022 Share Posted January 12, 2022 There's an option on the Table Import node to convert latitude and longitude to position on a sphere. Table Import (sidefx.com) The math can be done elsewhere if you want but that node makes it pretty easy. 1 Quote Link to comment Share on other sites More sharing options...
